- Mute
- Permalink
- Report
start with making a unique copy of your master assembly, and then do the configurating.
All sheets in one drawing, will cause a slow drawing (and later on problems with PDM if you use that)
saving should not be a problem after making the copy
if you get ....newver, normaly Inventor deletes that after the coppy is ready. in the past I saw this when the data was stored on a verry slow network drive. try this on you C:\, and see what happens.
saving a file is always in the master LOD.
best is not to work with LOD's because they give all kind of problems.....
with code you can set the right LOD again.
What you see in the assembly depends on the design view that is set at the assembly level. so maybe the subassembly is changed but in the designview "default" and in the assembly you see the master desginview of that subassembly. you can see this better by opening the subassembly. if it is changed, you code worked. then you need to change the designview setting in the main assy.
Kudo's are also appreciated
Succes on your project, and have a nice day
Herm Jan
