Charlies_3D_T
1393 Views, 11 Replies
Ilogic to add ilogic to event triggers
Does someon know if it's possible to add a ilogic rule to event triggers?
I want to run an ilogic rule and when it's finished i want it to be added to event triger at part geometry change.
Thank you!
search on inventor code injector
https://beinginventive.typepad.com/being-inventive/2012/02/injecting-ilogic-code-and-ilogic-event-tr...
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Thank you but I Already use that one. But I want to write a rule that does that specificaly.
the injector code is open, you can debug it.
there are many comment lines explaning things.
in the code you will find some code to set the events, but it is not so simple
Herm Jan
Hi, here is an example I hope it is useful, it is a rule that after executing is automatically added to event, in the category of geometry change. For your rule in particular, replace the text box with your rule, or with the subroutine you have. Regards!!!
Sub main()
MessageBox.Show("Example", "Title")
Events
End Sub
Sub Events
On Error Resume Next
	Dim EventPropSet As Inventor.PropertySet
	EventPropSet = GetiLogicEventPropSet(ThisApplication.ActiveDocument)
	EventPropSet.Add("Inicio", "PartBodyChanged ", 1200)
'After Open Document					: AfterDocOpen                 		: 400
'Close(Document)						: DocClose                     		: 500
'Before Save Document                   : BeforeDocSave           			: 700
'After Save Document               		: AfterDocSave               		: 800
'Any Model Parameter Change        		: AfterAnyParamChange   			: 1000
'Part Geometry Change**            		: PartBodyChanged         			: 1200
'Material Change**                  	: AfterMaterialChange     			: 1400
'Drawing View Change***               	: AfterDrawingViewsUpdate  			: 1500
'iProperty(Change)                  	: AfterAnyiPropertyChange           : 1600
'Feature Suppression Change**          	: AfterFeatureSuppressionChange   	: 2000
'Component Suppression Change*   		: AfterComponentSuppressionChange 	: 2200
'iPart / iAssembly Change Component* 	: AfterComponentReplace   			: 2400
'New Document                         	: AfterDocNew                  		: 2600
InventorVb.DocumentUpdate()
End Sub
Function GetiLogicEventPropSet(cDocument As Document) As Inventor.PropertySet
		iLogicEventPropSet = cDocument.PropertySets.Item("iLogicEventsRules")
		If iLogicEventPropSet Is Nothing Then
			iLogicEventPropSet = cDocument.PropertySets.Item("_iLogicEventsRules")
		End If
		If iLogicEventPropSet.InternalName <> "{2C540830-0723-455E-A8E2-891722EB4C3E}" Then
			Call iLogicEventPropSet.Delete
			iLogicEventPropSet = cDocument.PropertySets.Add("iLogicEventsRules", "{2C540830-0723-455E-A8E2-891722EB4C3E}")
		End If
		End If
			MsgBox ("Unable to create the Event Triggers property for this file!", , "Event Triggers Not Set")
			Err.Raise(1)
			Exit Function
		End If
	On Error GoTo 0
	Return iLogicEventPropSet
End Function
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
@Sergio.D.Suárez
Thank you that was what i needed!!!
@Sergio.D.Suárez
Do you know how to declare the same rule but for an external rule?
So i want to place an external rule in the event triggers now. But if i change the name to the name of the external one it's not working.
LarsBJepsen
in reply to: Charlies_3D_T
Hi
@Charlies_3D_T  did you ever find a solution for declaring an external rule?
/Lars
Charlies_3D_T
in reply to: LarsBJepsen
@LarsBJepsen
What do you want to do?
For example if i want to use an external rule is use this command:
iLogicVb.RunExternalRule("FlatPattern")
But important for you is to set the settings inside inventor that it knows where you put your external rules.
LarsBJepsen
I'm trying to add and external rule to an event trigger as in the code previous in the tread. It looks like you had the same issue earlier?
/Lars
Charlies_3D_T
This is the solution normaly:
Sub Events
	' To make sure that the document has an iLogic DocumentInterest, add a temporary rule
	Dim tempRule = iLogicVb.Automation.AddRule(ThisDoc.Document, "TemporaryRule_392856A2", "")
	EventPropSet.Add("file://FlatPattern", "PartBodyChanged", 1250)
	iLogicVb.Automation.DeleteRule(ThisDoc.Document, tempRule.Name)
End Sub
		End If
		End If
		End If
			Err.Raise(1)
			Exit Function
		End If
	On Error GoTo 0
End Function
Hi Sergio,
thank you very much for that great code snippet. I'm new in VBA so how do I need to modify your snippet in case of I need to add multiple triggers? I think I need something like a loop to get this result (that is defined in my new Template).
Thank you for your support/tipps.
Br
Guido
