Hi Chandra Shekar;
In the interest of determining the parent of a standard part:
  1. if the parent is phantom, the true parent is the parent of the phantom parent. It is fine if the parent of parent is not phantom. I am OK up to this level.
  2. unfortunately, if the parent of parent is phantom, to find the parent of the standard part under consideration, I need to find the parent of parent of parent! This is where I need help. Rule and fake-sample assembly are attached here to. Could you help me to get this around.
In the sample, p0026 has sa0017, sa0012. Now, it is hard to decide the parent of each occurrences. To get this around (generally speaking, in case the parent's BOM structure is phantom), I would like to find:
  • parent of parent
I keep trying. Not sure will succeed. Please help.
Thanks.
