NirantarVidyarthee
462 Views, 4 Replies
Error creating top view
I am trying to create front and and top view of a part using VB.Net.
The code works fine with all other parts. How ever only one particular part is giving me problem.(Exception from HRESULT: 0x80070057 (E_INVALIDARG)))
The frontview is created all right, but it refuses to generate top view.
I have tried everything but can't find the clue.
The specific part and sample code (module) is attached.
Hey @NirantarVidyarthee ,
From the original code, the Point2d is at position (14, 13.9825), which is too close the the base view so that the projected view is failed to be created at this point.
Changing this line to enlarge coordinate a little bit can fix it:
Dim insTvY As Double = fv.Position.Y + (0.685 / 2.0) + 2
Jane Fan
Inventor QA Engineer
Thanks @JaneFan, it worked. But is there a way to predict the situation (of 'the point too close') before actually generating the projected view and getting an error? The value 2 may be smaller for some other part and may be too large for some other parts.
A little bit larger than half of base view height is fine, so we can change Y coordinate of project view referencing to base view height, like this:
insTvY = fv.Position.Y + (fv.Height / 2#) + 0.2
Jane Fan
No, its not related to fv.height but tv.Height.
