- Mute
- Permalink
- Report
Rikard,
Your solution worked. I made a couple adjustments based on the outputs I was getting in my Excel file.
1) When the plane offset was 0, Inventor was reporting the "full" volume. To correct this, I dumped the "full" volume into a new parameter value that is written into the last volume cell after the loop is finished. I also added another line to rewrite the volume at the 0 offset to be 0 gallons.
2) The iProperties.Volume value is in cubic inches. Therefore, I added some math to convert the cubic inches into gallons and rounded the figure to 1 decimal place.
3) I eliminated the "+1" at the beginning of the loop statement. This eliminated 1 loop from the sequence.
The final version of the iLogic code is pasted below.
InventorVb.DocumentUpdate() Feature.IsActive("Split1") = True i = 0 Parameter("Offset") = i * (1 in / 1 ul) GoExcel.Open("Table.xlsx", "Sheet1") String1 = "A4" String2 = "B4" GoExcel.CellValue(String1) = Parameter("Offset") GoExcel.CellValue(String2) = Round(iProperties.Volume / 231, 1) Parameter("Full") = Round(iProperties.Volume / 231, 1) Height = H2H Inc = 1 Do Until Parameter("Offset") > Height GoExcel.CellValue(String1) = Parameter("Offset") GoExcel.CellValue(String2) = Round(iProperties.Volume / 231, 1) i = i + Inc Parameter("Offset") = i * (1 in / 1 ul) Dim myChars() As Char = String1.ToCharArray() Dim resultString As String = "" For Each ch As Char In myChars If Char.IsDigit(ch) Then resultString = resultString & ch End If Next A = CStr(resultString) + Inc String1 = Left(String1,1) & CStr(A) String2 = Left(String2,1) & CStr(A) InventorVb.DocumentUpdate(False) 'required to get current mass properties Loop GoExcel.CellValue(String1) = Parameter("Offset") GoExcel.CellValue(String2) = Parameter("Full") GoExcel.CellValue("B4") = 0 GoExcel.Save GoExcel.Close Feature.IsActive("Split1") = False
I am very grateful for your time and expertise in helping me solve this. I will mark this topic as "Accepted Solution"
Sincerely,
Steven
