jan.pomplun
369 Views, 2 Replies
Problem with derived assembly
I have a problem with creating a derived part of an assembly. The assembly looks like the following:
When I derive it into a part via the GUI ("Ableiten" means derived part in english)
The derived part looks similar. When I do it via the API:
var partDoc = (Inventor.PartDocument)InventorUtil.InventorApplication.Documents.Add(Inventor.DocumentTypeEnum.kPartDocumentObject, "", false);
DerivedAssemblyDefinition defAss = partDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.CreateDefinition(invDelegate.Document.FullDocumentName);
defAss.InclusionOption = DerivedComponentOptionEnum.kDerivedIncludeAll;
defAss.DeriveStyle = DerivedComponentStyleEnum.kDeriveAsSingleBodyNoSeams;
partDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Add(defAss);
The derived part however looks like:
I do not understand why the marked feature is shown in the part - marked with the red circle.
I can only reproduce it in the GUI when I change the following to include the bounding box:
notice the green rectangle (should be bounding box instead of the plus).
I do not understand why this would be the default behaviour via the API - while it is not via the GUI.
Further (and more important) I do not know how to deactivate it. I tried around with following ptions which did not help
            defAss.DeriveStyle = DerivedComponentStyleEnum.kDeriveAsMultipleBodies;
            defAss.IncludeAllTopLevelWorkFeatures =DerivedComponentOptionEnum.kDerivedExcludeAll;
            defAss.IncludeAllTopLevelSketches = DerivedComponentOptionEnum.kDerivedExcludeAll;
            defAss.IncludeAllTopLeveliMateDefinitions = DerivedComponentOptionEnum.kDerivedExcludeAll;
            defAss.IncludeAllTopLevelParameters = DerivedComponentOptionEnum.kDerivedExcludeAll;
Does anyone know how to export the assembly without the "bounding box" features?
Jan
For this you should (could) use a View representation in the inventor assembly with that specific part suppressed.
Than use this View representation in your derived definition too...
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Autodesk Affiliations:
So is it correct that the API automatically includes the bounding box opposed to the GUI behaviour?
For this functionality the API can not reproduce all commands that would be done via GUI?
Thanks for the workaround, I will try.
