RoyWickrama_RWEI
1523 Views, 10 Replies
To Retrieve Parent, Parent of Parent etc for phantom sub-assemblies
I am developing a rule shown below to extract all the data required for the product documentation in huge assembly environment (couple of thousand drawings).
The rule has following functionalities:
  • reference documents (parts and assemblies) excluded
  • phantom parts excluded
  • phantom assemblies excluded
However, I still have a problem connected with some parts reside in one or multiple phantom parents. If the parent of a document (part) is of phantom BOM structure, the true parent of the document is the parent of parent and so on until the parent of normal BOM structure is hit.
From my side, if I know the parent of parent, I can get around this issue (at the bottom of this rule). But, it looks like a lot to do!
Could you help, please. Thanks.
Public Class RWEI_0010BOM
	Shared oTextSave As String = "C:\Users\Public\Documents\iLogicBuffer.txt"
Sub Main
	Dim oAssy_ThisDoc As AssemblyDocument
	Dim oDoc As Document = ThisApplication.ActiveDocument
	Dim iL_NO As String = "0010-BOM"
	oDelete_ex_Notepad(oTextSave, iL_NO)
	Dim HL1_Prefix As String = "FILE REFERENCE TREE RAN FROM: "
	oHL1 = HL1_Prefix & oDoc.FullFileName
	oWrite_HeaderLines(oTextSave, oHL1)
	Dim iL_Name As String = "All Occurrences with BOM Structure"
	Dim oHL2 As String = "Rule " & iL_NO & ": " & iL_Name
	oWrite_HeaderLines(oTextSave, oHL2)
	Dim oDashes As String = ""
	For i = 1 To Len(oHL2)
	oDashes = oDashes & "-"
	Next i
	Dim oHL3 As String = oDashes
	oWrite_HeaderLines(oTextSave, oHL3)
	Dim oHL4 As String = ""
	oWrite_HeaderLines(oTextSave, oHL4)
Dim oBOM As BOM
oBOM = ThisApplication.ActiveDocument.ComponentDefinition.BOM
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item("Unnamed")'Accesing to Model data Column
'In English__"Unnamed"_"Structured"_"Parts Only"__In Spanish__"Sin nombre"_"Estructurado"_"Solo piezas"
  Call ListItems(oBOMView.BOMRows, 0)
Process.Start("Notepad.exe", oTextSave)
End Sub
Sub ListItems(Rows As BOMRowsEnumerator, indent As Integer)
    Dim oBOMRow As BOMRow
    For Each oBOMRow In Rows
			Dim oDef As ComponentDefinition
			oDef = oBOMRow.ComponentDefinitions(1)
			Dim oLFN  As String
			oLFN  = oDef.Document.Displayname
			Dim oDocFile As Document
			oDocFile = oDef.Document
			If oDocFile.IsModifiable = True Then
				Dim oBOMStructnumber As String
			    oBOMStructnumber = oBOMRow.BOMStructure
				Dim BOM_Structure As String
				If oBOMStructnumber <> 51972 Then
				If oBOMStructnumber = 51969 Then BOM_Structure = "Default"
				If oBOMStructnumber = 51974 Then BOM_Structure = "Inseparable"
				If oBOMStructnumber =  51970 Then BOM_Structure = "Normal"
				If oBOMStructnumber = 51971 Then BOM_Structure = "Phantom"
				If oBOMStructnumber =  51973 Then BOM_Structure = "Purchased"
				If oBOMStructnumber = 51972 Then BOM_Structure = "Reference"
				If oBOMStructnumber = 51975 Then BOM_Structure = "The Structure Type varies amongst references"
	'			Dim oDocFile As Document
	'			oDocFile = oDef.Document
	'			If oDocFile.IsModifiable = True Then
				Dim Parent As Document = oDocFile.ReferencingDocuments.Item(1)
				    If Not oBOMRow.ChildRows Is Nothing Then
				        Call ListItems(oBOMRow.ChildRows, indent + 1)
				    End If
					Dim oPhantomPart_ParentOfPhantomPart As String = ""
					If Right(oLFN, 3) = "ipt" And BOM_Structure = "Phantom" Then
						'Do nothing
					Else
						If Right(oLFN, 3) = "iam" And BOM_Structure = "Phantom" Then
							'Do nothing
						Else If Right(oLFN, 3 = "ipt" And BOM_Structure = "Phantom" Then
'oPhantomPart_ParentOfPhantomPart = oLFN & "$" & Parent.DisplayName Else oName_Parent = Parent.DisplayName & "$" & BOM_Structure & "$" & oLFN oWrite_Data(oTextSave, oName_Parent) End If End If End If End If Next End Sub Sub oWrite_HeaderLines(oTextSave As String, oHeaderLine As String) oWrite = System.IO.File.AppendText(oTextSave) oWrite.WriteLine(oHeaderLine) oWrite.Flush() oWrite.Close End Sub Sub oWrite_Data(oTextSave As String, oData As String) oWrite = System.IO.File.AppendText(oTextSave) oWrite.WriteLine(oData) oWrite.Flush() oWrite.Close End Sub Sub oDelete_ex_Notepad(oTextSave As String, iL_NO As String) 'To delete oTextSave if existing. If System.IO.File.Exists(oTextSave) = True Then System.IO.File.Delete(oTextSave) End If End Sub End Class
