02-22-2019
09:06 AM
- Mute
- Permalink
- Report
02-22-2019
09:06 AM
Finally I found out myself how to check if the link is already existing... in case it is there it will delete it
I have now a complete function which saves PDF,DXF and STP of a drawing and attaches the "Export" files to the drawing. So when I check it into the vault all files are there...
PDF/DXF/STEP Export is not included in the code below...
Option Explicit On
Sub Main()
'current document
Dim doc As Inventor.Document = ThisDoc.Document
Dim oleReference As ReferencedOLEFileDescriptor = Nothing
Dim selectedfilePDF As String = String.Empty
Dim selectedfileDXF As String = String.Empty
Dim selectedfileSTP As String = String.Empty
'Verify the current document has been saved.
If doc.FullFileName = "" Then
MessageBox.Show("This document must be saved first.")
Exit Sub
End If
' Link file
Try
selectedfilePDF = "C:\Vault_WORK\TC_VAULT\DOCUMENTS\KS US\00_EXPORT-2D\" & "EXPORT_" & ThisDoc.FileName(False) & ".pdf"
selectedfileDXF = "C:\Vault_WORK\TC_VAULT\DOCUMENTS\KS US\00_EXPORT-2D\" & "EXPORT_" & ThisDoc.FileName(False) & ".dxf"
selectedfileSTP = "C:\Vault_WORK\TC_VAULT\DOCUMENTS\KS US\00_EXPORT-2D\" & "EXPORT_" & ThisDoc.FileName(False) & ".stp"
Catch
Return 'operation was cancelled by the user
End Try
AddReferencesPDF(doc, selectedfilePDF)
AddReferencesDXF(doc, selectedfileDXF)
AddReferencesSTP(doc, selectedfileSTP)
End Sub
'PDF-Attachment
Public Function AddReferencesPDF(ByVal odoc As Inventor.Document, ByVal selectedfilePDF As String)
Dim OLERefPDF As ReferencedOLEFileDescriptor = Nothing
Dim OLERefsPDF As ReferencedOLEFileDescriptors = doc.ReferencedOLEFileDescriptors
Try
OLERefPDF = OLERefsPDF.ItemByName(selectedfilePDF)
' File is already attached - delete the attachment so it can be recreated...
OLERefPDF.Delete()
Catch
' The file is not already attached - continue...
End Try
Try
OLERefPDF = doc.ReferencedOLEFileDescriptors.Add(selectedfilePDF, OLEDocumentTypeEnum.kOLEDocumentLinkObject)
Catch
MsgBox("Failed to link to the file", 64, "Export vault")
Return False
End Try
End Function
'DXF-Attachment
Public Function AddReferencesDXF(ByVal odoc As Inventor.Document, ByVal selectedfileDXF As String)
Dim OLERefDXF As ReferencedOLEFileDescriptor = Nothing
Dim OLERefsDXF As ReferencedOLEFileDescriptors = doc.ReferencedOLEFileDescriptors
Try
OLERefDXF = OLERefsDXF.ItemByName(selectedfileDXF)
OLERefDXF.Delete()
Catch
End Try
Try
OLERefDXF = doc.ReferencedOLEFileDescriptors.Add(selectedfileDXF, OLEDocumentTypeEnum.kOLEDocumentLinkObject)
Catch
Return False
End Try
End Function
'STEP-Attachment
Public Function AddReferencesSTP(ByVal odoc As Inventor.Document, ByVal selectedfileSTP As String)
Dim OLERefSTP As ReferencedOLEFileDescriptor = Nothing
Dim OLERefsSTP As ReferencedOLEFileDescriptors = doc.ReferencedOLEFileDescriptors
Try
OLERefSTP = OLERefsSTP.ItemByName(selectedfileSTP)
OLERefSTP.Delete()
Catch
End Try
Try
OLERefSTP = doc.ReferencedOLEFileDescriptors.Add(selectedfileSTP, OLEDocumentTypeEnum.kOLEDocumentLinkObject)
Catch
Return False
End Try
End Function
