02-21-2019
09:25 AM
- Mute
- Permalink
- Report
02-21-2019
09:25 AM
Its an older post but maybe I get an answer here.
I used the rule above to attache pdf/stp/dxf exports to the file. It works fine.
My problem is the following.
When I change something on the drawing i will export the files again and it will automaticlly update the export-files always the same location. With my current rule it always adds new links in the 3rd party section. Can i add a command to the rule which is looking if these Reference is already existing, if so then just cancel and don't add new links?
Option Explicit On
Option Explicit On
Sub Main()
'current document
Dim doc As Inventor.Document = ThisDoc.Document
'Verify the current document has been saved.
If doc.FullFileName = "" Then
MessageBox.Show("This document must be saved first.")
Exit Sub
End If
'default folder
Dim FolderName As String = Left$(doc.FullFileName, InStrRev(doc.FullFileName, "\") )
Dim selectedfile As String = String.Empty
Dim selectedfile2 As String = String.Empty
Dim selectedfile3 As String = String.Empty
Dim oFileDlg As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
'oFileDlg.Filter = "Dwg files (*.dwg)|*.dwg|Excel files (*.xlsx)|*.xlsx|pdf files (*.pdf)|*.pdf|Inventor parts (*.ipt)|*.ipt|Inventor iFeatures (*.ide)|*.ide|Other files (*.*)|*.*"
'oFileDlg.InitialDirectory = FolderName
'oFileDlg.CancelError = True
'oFileDlg.MultiSelectEnabled = True
Try
'oFileDlg.ShowOpen()
selectedfile = "C:\Vault_WORK\TC_VAULT\DOCUMENTS\KS US\00_EXPORT-2D\" & ThisDoc.FileName(False) & ".pdf"
selectedfile2 = "C:\Vault_WORK\TC_VAULT\DOCUMENTS\KS US\00_EXPORT-2D\" & ThisDoc.FileName(False) & ".dxf"
selectedfile3 = "C:\Vault_WORK\TC_VAULT\DOCUMENTS\KS US\00_EXPORT-2D\" & ThisDoc.FileName(False) & ".stp"
Catch
Return 'operation was cancelled by the user
End Try
AddReferences(doc, selectedfile)
AddReferences2(doc, selectedfile2)
AddReferences3(doc, selectedfile3)
End Sub
Public Sub AddReferences(ByVal odoc As Inventor.Document, ByVal selectedfile As String)
Dim oleReference As ReferencedOLEFileDescriptor
oleReference = odoc.ReferencedOLEFileDescriptors _
.Add(selectedfile,OLEDocumentTypeEnum.kOLEDocumentLinkObject)
oleReference.BrowserVisible = True
oleReference.Visible = False
oleReference.DisplayName = Mid$(selectedfile, InStrRev(selectedfile, "\") + 1)
End Sub
Public Sub AddReferences2(ByVal odoc As Inventor.Document, ByVal selectedfile2 As String)
.Add(selectedfile2,OLEDocumentTypeEnum.kOLEDocumentLinkObject)
oleReference.DisplayName = Mid$(selectedfile2, InStrRev(selectedfile2, "\") + 1)
End Sub
Public Sub AddReferences3(ByVal odoc As Inventor.Document, ByVal selectedfile3 As String)
.Add(selectedfile3,OLEDocumentTypeEnum.kOLEDocumentLinkObject)
oleReference.DisplayName = Mid$(selectedfile3, InStrRev(selectedfile3, "\") + 1)
End Sub
