you need to use the pre and post events of the EDM vault add in of inventor.
Read this in the meanwhile:
https://forums.autodesk.com/t5/inventor-customization/use-inventor-vault-add-in-through-inventor-api...
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Autodesk Affiliations:
