@Scott.Hallmark ,
Yes, there is no direct Inventor API to split PartsList. But there is a way to copy or add new PartsList. Then, possible PartsListRow can be made invisible based on "Ship" values. As per sample PartsList, 6th column is considered as "Ship" column. Based on this, below VBA code can be used to create new partslist and hide respective "Ship" values.
Sub Split_PartsList()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDoc.ActiveSheet
    Dim oPartsList1 As PartsList
    Set oPartsList1 = oSheet.PartsLists.Item(1)
    Dim oPoint As Point2d
    Set oPoint = ThisApplication.TransientGeometry.CreatePoint2d(oPartsList1.RangeBox.MaxPoint.X, oPartsList1.RangeBox.MinPoint.Y)
    Dim oPartsList2 As PartsList
    Set oPartsList2 = oSheet.PartsLists.Add(oPartsList1.ReferencedDocumentDescriptor.ReferencedDocument, oPoint)
    'For "UNIT" Ship
    Dim oRow As PartsListRow
    For Each oRow In oPartsList1.PartsListRows
        If oRow.Item(6).Value = "LOOSE" Then
            oRow.Visible = False
        End If
    Next
    'For "LOOSE" Ship
    For Each oRow In oPartsList2.PartsListRows
        If oRow.Item(6).Value = "UNIT" Then
        End If
    Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
