tecnicoGL332
208 Views, 1 Reply
import publisher image for rush
hi to all, I would like to attach the logo of a product on it, that logo, and has been created with publishers, so I do not know how to do it. I had thought about using overhang, but when I amount the image, inventor wants 4,000 shares. Can someone help me? Thanks.
Sorry but for me it is not clear what you try to do!
Could you please explain a little more in detail what you try to do?
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Autodesk Affiliations:
