02-18-2019
06:26 AM
- Mute
- Permalink
- Report
02-18-2019
06:26 AM
Hi, I tweak your code a bit, I think it's now what you're looking for. Please check it out and see if we can improve it. regards
Public Class RWEI_0001A Shared oTextSave As String = "C:\Users\Public\Documents\iLogicBuffer.txt" Sub Main() 'Accessing Assembly Components @ https://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html Dim oDashes As String = "" Dim iL_NO As String = "0001A-BOM" Dim iL_Name As String = "All Occurrences with BOM Structure" Dim iL_FullName As String = "Rule " & iL_NO & ": " & iL_Name Dim oDoc As Document = ThisApplication.ActiveDocument oDelete_ex_Notepad(oTextSave, iL_NO) oHL1 = "FILE REFERENCE TREE RAN FROM: " & oDoc.FullFileName oWrite_HeaderLines(oTextSave, oHL1) oHL2 = iL_FullName oWrite_HeaderLines(oTextSave, oHL2) For i = 1 To Len(iL_FullName) oDashes = oDashes & "-" Next i oWrite_DashLine(oTextSave, oDashes) ' Get the active assembly. Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument ' Call the function that does the recursion. Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1) Process.Start("Notepad.exe", oTextSave) End Sub Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer) ' Iterate through all of the occurrence in this collection. This ' represents the occurrences at the top level of an assembly. Dim oOcc As ComponentOccurrence For Each oOcc In Occurrences ' Print the name of the current occurrence. ' Check to see if this occurrence represents a subassembly ' and recursively call this function to traverse through it. If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then Call TraverseAssembly(oOcc.SubOccurrences, Level + 1) End If Try Dim oParentocc As ComponentOccurrence oParentocc = oOcc.ParentOccurrence oParent = oParentocc.Name Catch oParent = System.IO.Path.GetFileNameWithoutExtension(oOcc.Parent.Document.DisplayName) End Try oData_X = oParent & "@" & oOcc.Name & "@" & "Level - " & Level oWrite_Data(oTextSave, oData_X) Next End Sub Function GetOccurrenceParent(oOcc As ComponentOccurrence, oOccName As String) Return oOcc.Parent.Document.DisplayName End Function 'Process.Start("Notepad.exe", oTextSave) Sub oWrite_Data(oTextSave As String, oData As String) oWrite = System.IO.File.AppendText(oTextSave) oWrite.WriteLine(oData) oWrite.Flush() oWrite.Close End Sub Sub oWrite_HeaderLines(oTextSave As String, oHeaderLine As String) oWrite = System.IO.File.AppendText(oTextSave) oWrite.WriteLine(oHeaderLine) oWrite.Flush() oWrite.Close End Sub Sub oWrite_DashLine(oTextSave As String, oDashes As String) oWrite = System.IO.File.AppendText(oTextSave) oWrite.WriteLine(oDashes) oWrite.Flush() oWrite.Close End Sub Sub oDelete_ex_Notepad(oTextSave As String, iL_NO As String) 'To delete oTextSave if existing. ' Dim FileDelete As String ' FileDelete = "C:\testDelete.txt" If System.IO.File.Exists(oTextSave) = True Then System.IO.File.Delete(oTextSave) MessageBox.Show("Existing (if any) File Deleted", iL_NO) End If End Sub End Class
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
