- Mute
- Permalink
- Report
Parts List Break based on "Ship" change
I have a Parts List that contains a custom property called "SHIP" and the only 2 values that should show up in this Parts List is either "UNIT" or "LOOSE". I would like to see if there is a way thru iLogic to break the parts list into 2 tables based on that change automatically. It currently sorts based on that property first, then the part number, so that the "LOOSE" items show up at the bottom of the parts list.
This is what I get now:
This is what I would like to get:
Scott Hallmark, Design Specialist | Fluor Corporation
Inventor and AutoCAD Certified Professional, Autodesk Certified Instructor | My Plant3D Notes | AU Speaker | ROLL TIDE!
- Mute
- Permalink
- Report
Hi @Scott.Hallmark ,
As I know splitting PartsList table is not supported in API and iLogic for now that we can only do that via manual operation.
Jane Fan
Inventor QA Engineer
- Mute
- Permalink
- Report
Yes, there is no direct Inventor API to split PartsList. But there is a way to copy or add new PartsList. Then, possible PartsListRow can be made invisible based on "Ship" values. As per sample PartsList, 6th column is considered as "Ship" column. Based on this, below VBA code can be used to create new partslist and hide respective "Ship" values.
Sub Split_PartsList()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDoc.ActiveSheet
Dim oPartsList1 As PartsList
Set oPartsList1 = oSheet.PartsLists.Item(1)
Dim oPoint As Point2d
Set oPoint = ThisApplication.TransientGeometry.CreatePoint2d(oPartsList1.RangeBox.MaxPoint.X, oPartsList1.RangeBox.MinPoint.Y)
Dim oPartsList2 As PartsList
Set oPartsList2 = oSheet.PartsLists.Add(oPartsList1.ReferencedDocumentDescriptor.ReferencedDocument, oPoint)
'For "UNIT" Ship
Dim oRow As PartsListRow
For Each oRow In oPartsList1.PartsListRows
If oRow.Item(6).Value = "LOOSE" Then
oRow.Visible = False
End If
Next
'For "LOOSE" Ship
For Each oRow In oPartsList2.PartsListRows
If oRow.Item(6).Value = "UNIT" Then
End If
Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
