- Mute
- Permalink
- Report
As a part of my rule, I need to write data into a text file. I noticed that, it keeps growing instead of creating a new text file.
Could someone help, please!
Thanks.
Public Class forBomStructure
Shared oTextSave As String = "C:\Users\Public\Documents\iLogicBuffer.txt"
Sub Main()
' create_txt(oWritex)
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oModelDoc As Document
Dim oStr As String = ""
Dim iL_Name as String = "0023A Full File Names of Occurrences"
oWrite_Sub(oWrite, "FILE REFERENCE TREE RAN FROM: " & oDoc.FullFileName)
oWrite_Sub(oWrite, "RULE: " & iL_Name)
oWrite_Sub(oWrite, "-----------------------------")
' Process.Start ("Notepad.exe", oTextSave)
' Exit Sub
For Each oModelDoc In oDoc.AllReferencedDocuments
'' RecurReferencing(oModelDoc, oStr, 0)
' MessageBox.Show("oModelDoc.Name: " & oModelDoc.FullFileName, "Title")
' oFFN_Document = oModelDoc.FullFileName
' oWrite_Sub(oWrite, oFFN_Document)
Next
End Sub
Sub oWrite_Sub(oWrite As System.IO.StreamWriter, oStr_to_Write As String)
oWrite = System.IO.File.AppendText(oTextSave)
oWrite.WriteLine(oStr_to_Write)
oWrite.Flush()
oWrite.Close
If My_Expression Then
End If
End Sub
End Class
- Mute
- Permalink
- Report
If you need everytime a new file than you can delete the old one before writing to it:
Dim FileDelete As String
FileDelete = "C:\testDelete.txt"
If System.IO.File.Exists( FileDelete ) = True Then
System.IO.File.Delete( FileDelete )
MsgBox("File Deleted")
End If
- Mute
- Permalink
- Report
@GeorgK is right. If text file is already exists, delete before creating this line (create_txt(oWritex)).
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
- Mute
- Permalink
- Report
Great help. It works.
Thanks. I added the following in my code:
Sub oDelete_ex_Notepad(oTextSave As String) 'To delete oTextSave if existing. Dim FileDelete As String FileDelete = "C:\testDelete.txt" If System.IO.File.Exists(oTextSave) = True Then System.IO.File.Delete(oTextSave) MsgBox("File Deleted") End If End Sub
- Mute
- Permalink
- Report
Hi Chandra,
I am trying to create a text file which gets all part names in an assembly written, however I am struggling to
work out how to combine both write & read of my text file lines and only add the next part name if it doesn't already exist in previous lines.
Here is a basic example where I can check if the name exists - but I am unsure how to then activate the append function with it (you'll see it commented out below) so I can then add the name if its unique:
oFile = "C:\Temp\Names.txt" oRead = System.IO.File.OpenText(oFile) Dim sLine As String = "" Do sLine2 = ThisDoc.FileName(False) sLine = oRead.ReadLine() If Not sLine Is Nothing Then If sLine <> sLine2 Then ' oAppend = IO.File.AppendText("C:\TEMP2\Test_File.txt") ' oAppend.WriteLine(ThisDoc.FileName(False)) ' oAppend.Flush() ' oAppend.Close() MsgBox(sLine2) End If End If Loop Until sLine Is Nothing oRead.Close() ThisDoc.Launch(oFile)
Any help would be appreciated. Thanks @chandra.shekar.g
- Mute
- Permalink
- Report
Try below iLogic code to write part name if does not exists.
Dim name As String = ThisDoc.FileName(False)
Dim Path As String = "C:\temp\Testing.txt"
Dim file As System.IO.StreamReader = New System.IO.StreamReader(path)
Dim found As Boolean = False
For Each Line As String In System.IO.File.ReadAllLines(path)
If Line.Contains(name) = True Then
found = True
Exit For
End If
Next
file.Close()
If found = False Then
oAppend = System.IO.File.AppendText(path)
oAppend.Flush()
oAppend.Close()
End If
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
- Mute
- Permalink
- Report
Thankyou so much @chandra.shekar.g
That has saved me so much time. I was originally sending each line to an excel file but
it is so much faster sending it to a txt file. I was just stuck on that duplicate name issue.
Much appreciated!
- Mute
- Permalink
- Report
@RoyWickrama_RWEI (@GeorgK ) Instead of
try
System.IO.File.CreateText(oTextSave)
According to this microsoft API article, :
Creates or opens a file for writing UTF-8 encoded text. If the file already exists, its contents are overwritten.
