in reply to: AlexFielder
ok here we go
Sub Main() Dim m_Inventor As Inventor.Application m_Inventor = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application") Dim oDoc As AssemblyDocument oDoc = m_Inventor.ActiveDocument Dim oCompdef As AssemblyComponentDefinition oCompdef = oDoc.ComponentDefinition Dim oBody1 As SurfaceBody Dim oBody2 As SurfaceBody oBody1 = m_Inventor.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select first body") oBody2 = m_Inventor.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select a body to compare") Dim oFace As Face Dim oAxis As WorkAxis Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(oPartDocument, "Hole Alignment") For Each oFace In oBody1.Faces If oFace.SurfaceType = SurfaceTypeEnum.kCylinderSurface Then oAxis = oCompdef.WorkAxes.AddFixed(oFace.Geometry.BasePoint, oFace.Geometry.AxisVector) Dim comparedFace As Face comparedFace = CompareFaces(oAxis, oBody2, oCompdef) If comparedFace Is Nothing Then oAxis.Name = oAxis.Name & "_misaligned" Else Dim oHoleFeature1 As HoleFeature oHoleFeature1 = oFace.CreatedByFeature Dim dia1 As Double dia1 = oHoleFeature1.HoleDiameter.Value dia1 = dia1 * 10 'Converting cm to mm Dim oHoleFeature2 As HoleFeature oHoleFeature2 = comparedFace.CreatedByFeature Dim dia2 As Double dia2 = oHoleFeature2.HoleDiameter.Value dia2 = dia2 * 10 'Converting cm to mm If Math.Round(dia1, 4) = Math.Round(dia2, 4) Then messagebox.Show("Hole diameter of plate 1 = " & dia1 & " compared with Hole diameter of plate 2 = " & dia2 & " => OK - Default") ElseIf Math.Round(dia1, 4) >= Math.Round(dia2, 4) And Math.Round(dia1, 4) <= Math.Round(dia2, 4) + 0.5 Then messagebox.Show("Hole diameter of plate 1 = " & dia1 & " compared with Hole diameter of plate 2 = " & dia2 & " => OK - Special Type") Else messagebox.Show("Hole diameter of plate 1 = " & dia1 & " compared with Hole diameter of plate 2 = " & dia2 & " => Not OK") End If End If End If Next Dim oPane As BrowserPane oPane = oDoc.BrowserPanes.ActivePane Dim alignedNodes As ObjectCollection alignedNodes = m_Inventor.TransientObjects.CreateObjectCollection Dim misAlignedNodes As ObjectCollection misAlignedNodes = m_Inventor.TransientObjects.CreateObjectCollection For i = 4 To oCompdef.WorkAxes.Count oAxis = oCompdef.WorkAxes.Item(i) Dim misaligned As Boolean misaligned = EndsWith(oAxis.Name, "misaligned") Dim oNode As BrowserNode If misaligned = True Then oNode = oPane.GetBrowserNodeFromObject(oAxis) misAlignedNodes.Add(oNode) Else oNode = oPane.GetBrowserNodeFromObject(oAxis) alignedNodes.Add(oNode) End If Next Dim alignedAxes As BrowserFolder alignedAxes = oPane.AddBrowserFolder("Aligned Axes", alignedNodes) Dim misAlignedAxes As BrowserFolder misAlignedAxes = oPane.AddBrowserFolder("MisAligned Axes", misAlignedNodes) trans.end End Sub Public Function CompareFaces(ByVal oAxis1 As WorkAxis, ByVal oBody As SurfaceBody, ByVal compDef As AssemblyComponentDefinition) As Face For Each oFace As Face In oBody.Faces If oFace.SurfaceType = SurfaceTypeEnum.kCylinderSurface Then Dim oAxis As WorkAxis oAxis = compDef.WorkAxes.AddFixed(oFace.Geometry.BasePoint, oFace.Geometry.AxisVector) If oAxis.Line.IsColinearTo(oAxis1.Line) Then oAxis.Delete() Return oFace Exit Function Else oAxis.Delete() End If End If Next Return Nothing End Function Public Function EndsWith(Str As String, ending As String) As Boolean Dim endingLen As Integer endingLen = Len(ending) EndsWith = (Microsoft.VisualBasic.Right(Trim(UCase(Str)), endingLen) = UCase(ending)) End Function
