01-22-2019
09:09 PM
- Mute
- Permalink
- Report
01-22-2019
09:09 PM
Actually, variable name (like BE_PC) and parameter name in drawing document are same. This is actual cause for errors.
Usually, all parameters in documents are defined with same variable name. For Example, If "BE_PC" parameter is defined in a document, "BE_PC" variable name is used in iLogic and can not be used again to another variable name.
In the attached rule, I can see all variable names are same as parameter names.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
