andrew_canfield
2007 Views, 10 Replies
External rule - Variable hides in an enclosing block - runs internally ok
hello
I've used copy & paste to move an iLogic rule which works locally to overwrite an external rule & now see this error:
How do I expose the variable?
Regards
Andrew
DRoam
in reply to: andrew_canfield
Variables declared within block statements like If/Then, Try/Catch, For/Next, etc. have "block scope" and are only available within the code block in which they're declared. So if you try to use them outside the block, you'll get a compile error.
To make the variable available to your entire procedure, declare it outside the Try/Catch block, and then just set its value within the Catch block, like this:
Dim oVariable As VariableType
Try
Catch
     oVariable = ...
End Try
I'm surprised this worked at all in your local rule. It's difficult to determine why without seeing more of your code. But regardless, you should only declare a variable within a block if it's ONLY going to be used in that block.
andrew_canfield
in reply to: DRoam
SyntaxEditor Code Snippet
Dim BE_PC as String
Dim DisciplineCode As String
I added the lines above at the start of the code but still see, 'BE_PC' hides & 'DisciplineCode' hides.
Thanks for looking.
Andrew
I watch an AU tutorial which suggested bug fixing using visual studio:
i'll need to watch it again!
DRoam
So did you get it working? If not, can you post your full code? (as text, not as a picture)
@andrew_canfield,
Actually, variable name (like BE_PC) and parameter name in drawing document are same. This is actual cause for errors.
Usually, all parameters in documents are defined with same variable name. For Example, If "BE_PC" parameter is defined in a document, "BE_PC" variable name is used in iLogic and can not be used again to another variable name.
In the attached rule, I can see all variable names are same as parameter names.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
andrew_canfield
in reply to: DRoam
Hello
I stripped the code back & the error message highlights a different line to what causes the problem:
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oDrawParams As UserParameters = oDrawDoc.Parameters.UserParameters
'oMyParameter = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
Try
'Change value of param
Parameter("BE_PC") = Parameter("BE_PC")
Catch
'Create Param as it doesn't exist
Dim BE_PC As UserParameter = oDrawParams.AddByValue("BE_PC" , "BE", UnitsTypeEnum.kTextUnits)
End Try
the above works, it's adding the code below which causes the error:
MultiValue.SetList("BE_PC", "BE", "PC")
BE_PC =  "BE"
So far:
Open a drawing, check if the required parameter is there - working
if it's not there create it - working
make the parameter multivalue - failing
the error is caused by lines 14 &  15 - not line 11:
Thanks again
Andrew
@andrew_canfield,
It would be better to test the error with document. So, please provide sample document to test the situation (Make sure that files are non confidential).
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Please find sample.idw attached
@andrew_canfield ,
Still I strongly believe that error is due to line 12. Below iLogic code does not throw error. Just changed variable name for userparameter from BE_PC to BE_PC_1.
BE_PC = "BE"' deleted parameter
Try
Catch
Dim BE_PC_1 As UserParameter = oDrawParams.AddByValue("BE_PC" , "BE", UnitsTypeEnum.kTextUnits)
End Try
BE_PC =  "BE"
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Thankyou - that works
