Are the drawing templates migrated correctly?
because it seems that the migration process is done at the moment you create a new drawing.
try this:
make a new drawing file.
then via file "save as template" button. and save it to the template location.
then create a new drawing from this template.
let me know if it has the same behavior or not.
regards
Arthur Knoors
Autodesk Affiliations:
