isocam
729 Views, 8 Replies
iProperties Dialog Box - Display "Physical" Tab Using a VBA Macro
Can  anybody help?
I have the following line of code in a VBA macro to display the iProperties dialog box
ThisApplication.CommandManager.ControlDefinitions.Item("AppiPropertiesWrapperCmd").Execute
Is it possible to open the iProperties dialog box and automatically show the "Physical" Tab without having to select it manually?
Many thanks in advance!
Darren
bradeneuropeArthur
in reply to: isocam
Unfortunately think it is not.
Why not creating your own dialog with the physical properties on it?
Arthur Knoors
Autodesk Affiliations:
BrianEkins
in reply to: isocam
The Inventor API does not support this.  It should be possible to do using the Windows API, but it wouldn't be trivial to do.
Brian Ekins
I have added some Vba code:
For a userform.
Private Sub UserForm_Activate()
Dim a As Application
Set a = ThisApplication
Dim b As PartDocument
Set b = a.ActiveDocument
Dim Mass As MassProperties
Set Mass = b.ComponentDefinition.MassProperties
TextBox1.Text = Mass.Accuracy
'TextBox2.Text = Mass.AchievedAccuracy(
TextBox3.Text = Mass.Area
TextBox4.Text = Mass.AvailableAccuracy
TextBox5.Text = Mass.CacheResultsOnCompute
TextBox6.Text = Mass.CenterOfMass.X & " " & Mass.CenterOfMass.Y & " " & Mass.CenterOfMass.Z
TextBox7.Text = Mass.IncludeCosmeticWelds
'TextBox8.Text = Mass.IncludeQuantityOverrides
TextBox9.Text = Mass.Mass
TextBox10.Text = Mass.MassOverridden
'TextBox11.Text = Mass.PrincipalMomentsOfInertial
'TextBox12.Text = Mass.RadiusOfGyration
'TextBox13.Text = Mass.RotationToPrincipal
TextBox14.Text = Mass.Type
TextBox15.Text = Mass.Volume
TextBox16.Text = Mass.VolumeOverridden
'TextBox17.Text = Mass.XYZMomentsOfInertia
'LABELS
Label1.Caption = "Mass.Accuracy"
'Label2.Caption = "Mass.AchievedAccuracy"
Label3.Caption = "Mass.Area"
Label4.Caption = "Mass.AvailableAccuracy"
Label5.Caption = "Mass.CacheResultsOnCompute"
Label6.Caption = "Mass.CenterOfMass" ' & " " & Mass.CenterOfMass.Y & " " & Mass.CenterOfMass.Z"""
Label7.Caption = "Mass.IncludeCosmeticWelds"
'Label8.Caption = Mass.IncludeQuantityOverrides
Label9.Caption = "Mass.Mass"
Label10.Caption = "Mass.MassOverridden"
'Label11.Caption = Mass.PrincipalMomentsOfInertial
'Label12.Caption = Mass.RadiusOfGyration
'Label13.Caption = Mass.RotationToPrincipal
Label14.Caption = "Mass.Type"
Label15.Caption = "Mass.Volume"
Label16.Caption = "Mass.VolumeOverridden"
'Label17.Caption = Mass.XYZMomentsOfInertia
End Sub
I have added the Project for VBA too:
load this into your VBA environment.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
@isocam,
@BrianEkins is right. Unfortunately, Inventor API does not support to display "Physical" tab. please suggest this wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Ofcourse this is possible, you need to use Execute2 and then you can send keys to any dialog with vba
Sub ActivatePhysicalTab()
ThisApplication.CommandManager.ControlDefinitions.Item("AppiPropertiesWrapperCmd").Execute2 (False)
Call SendKeys("{%}")
Call SendKeys("{RIGHT}")
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Good possible solution!
The only thing is that send keys are a bit tricky, regarding their possible unwanted behavior!
Arthur Knoors
@bradeneuropeArthur i know, but i don't see any issues with this one here.
I've done it in the past for settings in dialogs for example Detail views, and there indeed you need to watch out for unexpected behaviour.
DRoam
in reply to: frederic.vandenplas
I had some trouble with the snippets above, and I was also trying to get it to work in iLogic rather than VBA. After experimenting, the following methods seem to work well for VBA and iLogic respectively:
VBA:
Sub OpenPhysicalProperties()
    SendKeys ("{RIGHT 6}")
End Sub
iLogic
    ThisApplication.CommandManager.ControlDefinitions.Item("AppiPropertiesWrapperCmd").Execute2(False)
    System.Windows.Forms.SendKeys.SendWait("{RIGHT 6}")
End Sub
