in reply to: JamieVJohnson2
Thanks for the reply.
Yes that's how I'm used to orbiting by using the keyboard + mouse, but I'm looking for a method for orbiting that doesnt require the use of two device inputs where only one would normally suffice. I mean shift orbiting is fine and I'm used to it, wich is why I would never pay 700$ just to avoid having to hold shift by buying a space mouse wich is only good for that one single use as far as I can tell.
For instance, if I were able to map keys to the different angles (wich the mouse allows for, but as far as I can tell, Inventor does not) I would be more or less sorted. The only annoyance in that case would be not having analog input. Atleast that should work untill I get a response from the manufacturer wich lists autodesk programs as supported.
