RoyWickrama_RWEI
2609 Views, 7 Replies
Error message: Object variable or With block variable not set
When I run my rule in the drawing document, I get the above error message. Request help.
Message.pngInventor Professional 2019
Vault Professional 2019
Could you upload the code by text?
Arthur Knoors
Autodesk Affiliations:
His code is in the .idw file.
The code attempts to USE a property, then catches the error then creates the property.  The Catch then creates the property, but you then used the variable prop in the message box.  However you forgot to add "prop = "on the previous add line. (hi2 runs, hi2.1 runs, then error) .
Catch
	MsgBox("hi2")
		customPropertySet.Add("TEST", oCustiProperties_Array.Item(i))
			MsgBox("hi2.1")
		MessageBox.Show(prop.Name & ": ADDED" & vbLf & prop.Name & " (VALUE): " & prop.Value, "CUST PROP")
			MsgBox("hi2.2")
		oPrompt = "ASSIGN DATA"
			MsgBox("hi2.3")
	End Try
jvj
Thanks for the reply. My badness: after struggling few hours, I rushed to post for help.
Files are attached here to and code is shown below;
Sub main()
oCust_Prop_Sub()
End Sub
Sub oCust_Prop_Sub()
'Define the open document
Dim openDoc As Document
openDoc = ThisDoc.Document
'Look at the model file referenced in the open document
Dim docFile As Document
If ThisDoc.ModelDocument IsNot Nothing Then
docFile = ThisDoc.ModelDocument
Else
MessageBox.Show("NOT OK, This drawing has no model reference", "iLogic")
Return
End If
'oModelDoc = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
'format model file name
Dim FNamePos As Long
FNamePos = InStrRev(docFile.FullFileName, "\", -1)
Dim docFName As String
docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
'define the property set
customPropertySet = docFile.PropertySets.Item("Inventor User Defined Properties")
oName_Prop1 = "TOTAL QTY"
oName_Prop2 = "ROLLING_ALLOWANCE"
Dim oCustiProperties_Array As New ArrayList
oCustiProperties_Array.Add(oName_Prop1)
oCustiProperties_Array.Add(oName_Prop2)
For i = 0 To oCustiProperties_Array.Count-1
	'look for the custom propety and add it if not found
	Try
		prop = customPropertySet.Item(oCustiProperties_Array.Item(i))
		MessageBox.Show(prop.Name & ": EXISTS" _
		oPrompt = "EDIT/ASSIGN DATA"
	Catch
		MessageBox.Show(prop.Name & ": ADDED" _
	End Try
	prop.Value = InputBox(oPrompt, prop.Name, prop.Value)
Next i
iLogicVb.UpdateWhenDone = True
InventorVb.DocumentUpdate()
End Sub
Roy Wickrama
Sub main()
oCust_Prop_Sub()
End Sub
Else
Return
End If
	Try
	Catch
prop = customPropertySet.Item(oCustiProperties_Array.Item(i)) MessageBox.Show(prop.Name & ": ADDED" _ & vbLf & prop.Name & " (VALUE): " & prop.Value, "CUST PROP") oPrompt = "ASSIGN DATA" End Try prop.Value = InputBox(oPrompt, prop.Name, prop.Value) Next i iLogicVb.UpdateWhenDone = True InventorVb.DocumentUpdate() End Sub
Arthur Knoors
@bradeneuropeArthur, the .Add command returns the object.  So his modification works fine as a one liner, and doesn't require the second line to get the item.
prop = customPropertySet.Add("TEST", oCustiProperties_Array.Item(i))
jvj
That is correct!
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Dear Bradedeurope;
Thanks a lot.
It runs too smooth.
I will build up the rest of my rule.Your code is a great help.
Roy Wickrama
