@JamieVJohnson2,
A workaround is found. After rebuilding document and breaking links, sketch entities links are broken properly. Can you please try below iLogic code?
Sub Main()
	Dim oDoc As PartDocument
	oDoc = ThisApplication.ActiveDocument
	Dim oDef As PartComponentDefinition
	oDef = oDoc.ComponentDefinition
	Call oDoc.Rebuild()
	Dim oSketch As Sketch
	oSketch = oDef.Sketches.Item("Sketch5")
	BreakAllLinks(oSketch)
End Sub
Public Sub BreakAllLinks(sketch As Sketch)
		sketch.Edit()
        For Each en As SketchEntity In sketch.SketchEntities
            en.Reference = False
        Next
		sketch.ExitEdit()
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
