01-04-2019
09:10 AM
- Mute
- Permalink
- Report
01-04-2019
09:10 AM
Thank You, it works, i need to add :
WriteOutPropertySets
but.... can't this be done easier? i got just a few property to read/set from know one general drawing.
Read/set from model is much more easier.
SyntaxEditor Code Snippet
iProperties.Value("Project", "Part Number") = iProperties.Value("assembly.iam","Project", "Part Number")
I wonder why it can't be like this :
iProperties.Value("assembly1.dwg","Summary", "Manager")= iProperties.Value("assembly2.dwg","Summary", "Manager")
Class ThisRule Shared my_title As String Sub Main() Dim docBase As Inventor.Document = ThisApplication.Documents.Open("f:\.......\ProjectName\Drawing1.dwg") Dim docChild As Inventor.Document = ThisApplication.Documents.Open("f:\.........\ProjectName\subassembly\Drawing2.dwg") ReadOutPropertySets(docBase) WriteOutPropertySets(docChild) End Sub Public Sub ReadOutPropertySets(invDoc As Inventor.Document) Try Dim strPropertySets As String = "Inventor Property Sets" & vbCrLf & "{Property Set Name}" & vbCrLf & "{Property.DisplayName, Property.Name, Property.ID, Property.Type, Property.Expression, Property.Value}" For Each pset As PropertySet In invDoc.PropertySets strPropertySets += vbCrLf & pset.Name For Each prop As [Property] In pset Try strPropertySets += vbCrLf & " " & prop.Name & prop.Value If prop.Name = "Title" Then my_title = prop.Value Catch ex As Exception End Try Next Next 'MsgBox(strPropertySets) Catch ex As Exception End Try End Sub Public Sub WriteOutPropertySets(invDoc As Inventor.Document) Try Dim strPropertySets As String = "Inventor Property Sets" & vbCrLf & "{Property Set Name}" & vbCrLf & "{Property.DisplayName, Property.Name, Property.ID, Property.Type, Property.Expression, Property.Value}" For Each pset As PropertySet In invDoc.PropertySets strPropertySets += vbCrLf & pset.Name For Each prop As [Property] In pset Try strPropertySets += vbCrLf & " " & prop.Name & prop.Value If prop.Name = "Title" Then prop.Value=my_title Catch ex As Exception End Try Next Next 'MsgBox(strPropertySets) Catch ex As Exception End Try End Sub End Class
