- Mute
- Permalink
- Report
What did you define bomStruc as? It should be of type BOMStructureEnum, but I can't verify that from your snippet. The other question, is the system attempting to report a BOMStructureEnum value that is not in the Enum list? 51969-51975. Welded parts are generally (by default) 51974 - Inseparable.
For it to say E_NotImplemented means the API is being asked to do something that wasn't completely written for it. But this feature has been around in version 10, so that shouldn't be the case. Unless they broke something, or your document is somehow corrupted, and in the process of getting that value, it runs into a sub-error that bubbles up as shown.
To aide in removing corruption from the equation, use the total-rebuild feature on all documents (or do a migration with total-rebuild feature turned on). If possible it would be helpful to see a copy of the document with the welded structure that is failing. Perhaps if only a single set of 2 parts and a single weld (if that also fails). We can use that to dive deeper with you.
