JamieVJohnson2
in reply to: mblaptok
Possible, certainly.
  1. Are you coping properties to a file that does not have them even defined, or just copying the values from one document to another that have the defined property, but not the right value?
  2. Do you know the name of each property,
    1. or is it 'random' and need to copy all properties,
    2. or all properties of a PropertySet (like custom properties only)
    3. or properties with a known keyword.
Open both documents into memory, and start getting properties and values from one placed into another.  Have you attempted to create a rule yet, if so can we see where you are at, if not let us know and we can get you going down the right path.
jvj
