JamieVJohnson2
Create a new workplane using the option Midplane between two planes, then use that workplane to mirror instead of your origin, because your model is asymmetrical.
 Alternatively you can use Parallel to plane on point, and pick the midpoint of a horizontal edge, and then the origin plane parallel to your desired mirror plane.
However, since your trapezoidal vertical face is not symmetrical, the new face will not 'connect' as expected.
jvj
