01-02-2019
01:39 PM
- Mute
- Permalink
- Report
01-02-2019
01:39 PM
Export commands use the translator add-in for that file format. The translator add-in via code can be thoroughly customized. For the user, the customization comes from the 'options' button. For DXF/DWG/DWF user customization can be saved as .INI files that the code can load and use as is instead of customizing each feature.
It is possible you are using 2 different customizations when exporting via code vs user.
jvj
