in reply to: clutsa
The new origin it is not a point, but as an origin it have 3 planes, 3 axis and a central point (see origin.jpg).
So, the point X, Y, Z i need is not a distance or offset, but a point position with the 3 coordinates completely different because central point and axis directions are different.
When you use the measuring tool, if you click only a point the windows gives you the position referred to an origin (see position.jpg). In the same windows you can select from a list box a different origin, and you get the coordinates rererred to another "triade".
So I can't do it measuring a distance between two point (or offset), due to different axis direction too.
