iLogic's only easy method is the iLogic browser which is not ribbon based, but it is a nifty dockable palette.  However, iLogic editor allows you to write VB.Net code, from there you can write a command that can edit the ribbon, and add one or many CommandControls.  If your going that far, you could write a complete add-in using straight up vb.net and visual studio, that autoloads every time Inventor opens (next level stuff = learning curve).
jvj
