Scott.Hallmark
298 Views, 1 Reply
total qty callout based on stock number and length instead of part number
As the title says, I am needing code to give a total qty based on stock number & length instead of part number.  We generate a cut list sheet of extruded metal parts, that may or may not have different fab (holes, notches, etc) and different part numbers, but the stock number and length are the same.  Looking for code to drop a "Total <Stock Numbers> at <Length>: <Total Qty>" callout on the DWG and will repeat for each Length that is different.
** If my reply resolves this issue, please choose Accept Solution **
Scott Hallmark, Design Specialist | Fluor Corporation
Inventor and AutoCAD Certified Professional, Autodesk Certified Instructor | My Plant3D Notes | AU Speaker | ROLL TIDE!
