dgreatice
in reply to: arron.craig
Try this:
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawingDoc.ActiveSheet
Dim oWidthRevTable As Double
oWidthRevTable = 15.02 'Set you custom width table
Dim oTablePt As Point2d
oTablePt = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Border.RangeBox.MaxPoint.X - oWidthRevTable, oSheet.Border.RangeBox.MaxPoint.Y)'Add Revision table in Top Left Corner
If oSheet.RevisionTables.Count = 0 Then
    Dim oRevTable As RevisionTable
	oRevTable = oSheet.RevisionTables.Add(oTablePt)
	Dim oRevStyle As Style
	For Each oRevStyle In oDrawingDoc.StylesManager.RevisionTableStyles
	    If oRevStyle.Name = "ABC Rev Table" Then
	        oRevTable.Style = oRevStyle
	    End If
	Next
Else
    MessageBox.Show("Revision Table already exist", "Autodesk Inventor")
End If
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
