arron.craig
540 Views, 2 Replies
ilogic rule for placing custom rev table on sheet
I'm trying to place a revision table from a defined style titled "ABC Rev Table".
I have tried to adapt the code from the this post but cannot find how to define which table to insert.
Using the API help I got as far as finding the RevisionTables.Add2 method which has an arg called
[RevisionTableStyle] As Variant but I have no idea how to use it,
RevisionTableStyle Variant Optional input RevisionTableStyle object that specifies the style to use for the table. If not provided, the default style is used.
