12-07-2018
12:59 PM
- Mute
- Permalink
- Report
12-07-2018
12:59 PM
When working this problem by hand, there is a checkbox in the options wizard, that allows you to select a specific sheet or sheets. When I saved that configuration into a *.ini file, I noticed an option that says "ALL SHEETS=No" under [EXPORT DESTINATION], however that file did not mention the sheet I selected. So at least I know there is access to this option.
In this code, I export with a bit more direct control over the actual translator. I suspect your answer lies in the oNameValueMap including something for the sheets to be printed.
Public Sub ExportACAD(settingsFile As String, isDWG As Boolean)
Dim invApp As Inventor.Application = TTSInventorTools.GetInventorApplication
' Set a reference to the DWG translator add-in.
Dim oDWGAddIn As TranslatorAddIn = Nothing
'USE DWG OR DXF FIND "DESTNATION DXF=Yes or No" in ini file (text file)
Dim ClassID As String = "{C24E3AC4-122E-11D5-8E91-0010B541CD80}"
Dim ext As String = ".dxf"
If isDWG Then
ClassID = "{C24E3AC2-122E-11D5-8E91-0010B541CD80}" ' = DWG TRANSLATOR
ext = ".dwg"
End If
Dim i As Long
For i = 1 To invApp.ApplicationAddIns.Count()
If invApp.ApplicationAddIns.Item(i).ClassIdString = ClassID Then
oDWGAddIn = invApp.ApplicationAddIns.Item(i)
Exit For
End If
Next
If oDWGAddIn Is Nothing Then
MsgBox("DWG add-in not found.", MsgBoxStyle.SystemModal)
Exit Sub
End If
' Check to make sure the add-in is activated.
If Not oDWGAddIn.Activated Then
oDWGAddIn.Activate()
End If
' Create a name-value map to supply informationto the translator.
Dim oNameValueMap As NameValueMap
oNameValueMap = invApp.TransientObjects.CreateNameValueMap()
' Create the name-value that specifiesthe ini file to use.
Call oNameValueMap.Add("Export_Acad_IniFile", settingsFile)
' Create a translation context and define that we want to output to a file.
Dim oContext As TranslationContext
oContext = invApp.TransientObjects.CreateTranslationContext()
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
' Define the type of output by specifying the filename.
Dim oOutputFile As DataMedium
oOutputFile = invApp.TransientObjects.CreateDataMedium()
oOutputFile.FileName = ACADFilePath & "\" & Name & ext
' Call the SaveCopyAs method of the add-in.
If Not System.IO.File.Exists(oOutputFile.FileName) Then
System.IO.Directory.CreateDirectory(System.IO.Path.GetDirectoryName(oOutputFile.FileName))
oDWGAddIn.SaveCopyAs(docINV, oContext, oNameValueMap, oOutputFile)
End If
End Sub
Not a complete answer but likely a point into the correct direction.
jvj
