1414 Views, 7 Replies
Edit an existing Extrusion with Ilogic / vba
i have an existing Extrusion. I won't to change this from increase to cut out.
The name of the Extrsion is "Bohrungen"
SourceSource
Won't change to:
Hole thrue allHole thrue all
I have found a code that change the direction but i don't know to change the extrusion to Cut thrue.
Here is the code that i have now:
SyntaxEditor Code Snippet
Sub Main
 Dim extrude As ExtrudeFeature = TryCast(Feature.InventorFeature("Bohrungen"), ExtrudeFeature)
 Dim extent As DistanceExtent = TryCast(extrude.Extent, DistanceExtent)
If Noppen = True Then
 extent.Direction = PartFeatureExtentDirectionEnum.kPositiveExtentDirection
Else
extent.Direction = PartFeatureExtentDirectionEnum.kNegativeExtentDirection
End If
End Sub
I have tested with the kCutOperation, but i don't know how?
Sincerely
