AlexFielder
1132 Views, 27 Replies
Long-term-stable ass'y w/ skeleton part producing "unexported in the source" msg
Hi all,
This is an odd one; for a customer we have been maintaining (but not adding to) a "configurator" that when I first looked had over 5,000 lines of iLogic code within it.
I refactored it down to around 1800 lines of iLogic and all has been mostly okay in the 18 month period since that last massive change.
The customer is upgrading to 2019 and of course wanted to continue using the configurator we had built for them.
I have migrated all the necessary files and during testing the following error appears on multiple occasions:
0000013469-Configuration Top Level Assembly-1-V4.iam: Errors occurred during update
     0000013469-LHC Door Assy-1-V4.iam: Errors occurred during update
       0000013469-LHC Door Intumescent-1-V4.ipt: Errors occurred during update
         One or more derived objects have had their Export status turned off in the source. Use the Design Doctor for treatment options.
           Type 6 Seal:2 : has been unexported in the source.
           VP Bead 1:4 : has been unexported in the source.
           VP Bead 7:4 : has been unexported in the source.
           VP Bead 4:4 : has been unexported in the source.
           VP Bead 236:4 : has been unexported in the source.
           VP Bead 7:3 : has been unexported in the source.
           VP Bead 5:2 : has been unexported in the source.
           VP Bead 4:3 : has been unexported in the source.
           VP Bead 236:3 : has been unexported in the source.
           VP Bead 1:3 : has been unexported in the source.
           Type 6 Seal:1 : has been unexported in the source.
           VP Bead 8:2 : has been unexported in the source.
           VP Bead 8:1 : has been unexported in the source.
           VP Bead 7:2 : has been unexported in the source.
           VP Bead 4:2 : has been unexported in the source.
           VP Bead 1:2 : has been unexported in the source.
           VP Bead 236:2 : has been unexported in the source.
           VP Bead 7:1 : has been unexported in the source.
           VP Bead 5:1 : has been unexported in the source.
           VP Bead 1:1 : has been unexported in the source.
           VP Bead 236:1 : has been unexported in the source.
           SP Bead 7:32 : has been unexported in the source.
           SP Bead 1:32 : has been unexported in the source.
           SP Bead 236:32 : has been unexported in the source.
           SP Bead 7:31 : has been unexported in the source.
           SP Bead 1:31 : has been unexported in the source.
           SP Bead 236:31 : has been unexported in the source.
           SP Bead 7:30 : has been unexported in the source.
           SP Bead 7:29 : has been unexported in the source.
           SP Bead 1:30 : has been unexported in the source.
           SP Bead 1:29 : has been unexported in the source.
           SP Bead 236:30 : has been unexported in the source.
           SP Bead 236:29 : has been unexported in the source.
           SP Seal:16 : has been unexported in the source.
           SP Seal:15 : has been unexported in the source.
           SP Bead 7:28 : has been unexported in the source.
           SP Bead 1:28 : has been unexported in the source.
           SP Bead 236:28 : has been unexported in the source.
           SP Bead 7:27 : has been unexported in the source.
           SP Bead 1:27 : has been unexported in the source.
           SP Bead 236:27 : has been unexported in the source.
           SP Bead 7:26 : has been unexported in the source.
           SP Bead 7:25 : has been unexported in the source.
           SP Bead 1:26 : has been unexported in the source.
           SP Bead 1:25 : has been unexported in the source.
           SP Bead 236:26 : has been unexported in the source.
           SP Bead 236:25 : has been unexported in the source.
           SP Seal:14 : has been unexported in the source.
           SP Seal:13 : has been unexported in the source.
           SP Bead 7:24 : has been unexported in the source.
           SP Bead 1:24 : has been unexported in the source.
           SP Bead 236:24 : has been unexported in the source.
           SP Bead 7:23 : has been unexported in the source.
           SP Bead 1:23 : has been unexported in the source.
           SP Bead 236:23 : has been unexported in the source.
           SP Bead 7:22 : has been unexported in the source.
           SP Bead 7:21 : has been unexported in the source.
           SP Bead 1:22 : has been unexported in the source.
           SP Bead 1:21 : has been unexported in the source.
           SP Bead 236:22 : has been unexported in the source.
           SP Bead 236:21 : has been unexported in the source.
           SP Seal:12 : has been unexported in the source.
           SP Seal:11 : has been unexported in the source.
           SP Bead 7:20 : has been unexported in the source.
           SP Bead 1:20 : has been unexported in the source.
           SP Bead 236:20 : has been unexported in the source.
           SP Bead 7:19 : has been unexported in the source.
           SP Bead 1:19 : has been unexported in the source.
           SP Bead 236:19 : has been unexported in the source.
           SP Bead 7:18 : has been unexported in the source.
           SP Bead 1:18 : has been unexported in the source.
           SP Bead 236:18 : has been unexported in the source.
           SP Bead 7:17 : has been unexported in the source.
           SP Bead 1:17 : has been unexported in the source.
           SP Bead 236:17 : has been unexported in the source.
           SP Bead 7:16 : has been unexported in the source.
           SP Bead 7:15 : has been unexported in the source.
           SP Bead 7:14 : has been unexported in the source.
           SP Bead 7:13 : has been unexported in the source.
           SP Bead 1:16 : has been unexported in the source.
           SP Bead 1:15 : has been unexported in the source.
           SP Bead 1:14 : has been unexported in the source.
           SP Bead 1:13 : has been unexported in the source.
           SP Bead 236:16 : has been unexported in the source.
           SP Bead 236:15 : has been unexported in the source.
           SP Bead 236:14 : has been unexported in the source.
           SP Bead 236:13 : has been unexported in the source.
           SP Seal:10 : has been unexported in the source.
           SP Seal:9 : has been unexported in the source.
           SP Seal:8 : has been unexported in the source.
           SP Seal:7 : has been unexported in the source.
           SP Bead 7:12 : has been unexported in the source.
           SP Bead 1:12 : has been unexported in the source.
           SP Bead 236:12 : has been unexported in the source.
           SP Bead 7:11 : has been unexported in the source.
           SP Bead 1:11 : has been unexported in the source.
           SP Bead 236:11 : has been unexported in the source.
           SP Bead 7:10 : has been unexported in the source.
           SP Bead 1:10 : has been unexported in the source.
           SP Bead 236:10 : has been unexported in the source.
           SP Bead 7:9 : has been unexported in the source.
           SP Bead 1:9 : has been unexported in the source.
           SP Bead 236:9 : has been unexported in the source.
           SP Seal:6 : has been unexported in the source.
           SP Seal:5 : has been unexported in the source.
           SP Bead 7:8 : has been unexported in the source.
           SP Bead 1:8 : has been unexported in the source.
           SP Bead 236:8 : has been unexported in the source.
           SP Bead 7:7 : has been unexported in the source.
           SP Bead 1:7 : has been unexported in the source.
           SP Bead 236:7 : has been unexported in the source.
           SP Bead 7:6 : has been unexported in the source.
           SP Bead 1:6 : has been unexported in the source.
           SP Bead 236:6 : has been unexported in the source.
           SP Bead 7:5 : has been unexported in the source.
           SP Bead 1:5 : has been unexported in the source.
           SP Bead 236:5 : has been unexported in the source.
           SP Seal:4 : has been unexported in the source.
           SP Seal:3 : has been unexported in the source.
           SP Bead 7:4 : has been unexported in the source.
           SP Bead 236:4 : has been unexported in the source.
           SP Bead 1:4 : has been unexported in the source.
           SP Bead 7:3 : has been unexported in the source.
           SP Bead 236:3 : has been unexported in the source.
           SP Bead 1:3 : has been unexported in the source.
           SP Seal:2 : has been unexported in the source.
           SP Seal:1 : has been unexported in the source.
           SP Bead 7:2 : has been unexported in the source.
           SP Bead 236:2 : has been unexported in the source.
           SP Bead 1:2 : has been unexported in the source.
           SP Bead 7:1 : has been unexported in the source.
           SP Bead 236:1 : has been unexported in the source.
           SP Bead 1:1 : has been unexported in the source.
Which of course is less than ideal. The one and only result on Google basically says: "open each Derived Component Object in the erroring part and DO NOTHING, then click okay" that I simply have no idea how to circumvent using the API.
These part files have not been modified in any way during the migration process (aside from the obvious save), so what on earth is going on and how do I fix it?
Alex.
