in reply to:
11:58 AM
- Mute
- Permalink
- Report
12-02-2018
11:58 AM
Reasonably cleaned up version of final code:
Function func_ConvertFolderContentToJT(ByVal strSourceFolder As String, ByVal strSourceFileType As String, ByVal strDestinationFolder As String, ByVal strDestinationFileType As String, ByVal strConverterConfigFilePath As String) As Boolean
func_ConvertFolderContentToJT = True
Dim objFS As FileSystemObject
Set objFS = CreateObject("Scripting.FileSystemObject")
If Right(strSourceFolder, 1) <> "\" Then
strSourceFolder = strSourceFolder & "\"
End If
If objFS.FolderExists(strSourceFolder) <> True Then
func_ConvertFolderContentToJT = False
Exit Function
End If
If strDestinationFolder <> "" Then
If objFS.FolderExists(strDestinationFolder) <> True Then
strDestinationFolder = False
End If
If Right(strDestinationFolder, 1) <> "\" Then
strDestinationFolder = strDestinationFolder & "\"
End If
End If
If strSourceFileType = "" Then
Exit Function
End If
If strDestinationFileType = "" Then
Exit Function
End If
Dim strToLookFor As String
strToLookFor = strDestinationFileType
If Left(strDestinationFileType, 1) = "." Then
strToLookFor = Right(strDestinationFileType, Len(strDestinationFileType) - 1)
Else
strDestinationFileType = "." & strDestinationFileType
End If
If objFS.FileExists(strConverterConfigFilePath) = False Then
Exit Function
End If
Dim flg_TranslationAddInFound As Boolean
flg_TranslationAddInFound = False
Dim intAddIn As Long
intAddIn = 1
Do
If InStr(1, UCase(ThisApplication.ApplicationAddIns.Item(intAddIn).Description), UCase(strToLookFor)) > 0 Then
flg_TranslationAddInFound = True
Exit Do
End If
intAddIn = intAddIn + 1
Loop Until intAddIn = ThisApplication.ApplicationAddIns.Count + 1
If flg_TranslationAddInFound <> True Then
Exit Function
End If
Dim JTAddIn As TranslatorAddIn
Set JTAddIn = ThisApplication.ApplicationAddIns.ItemById(ThisApplication.ApplicationAddIns.Item(intAddIn).ClientId)
Dim oContext As TranslationContext
Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
Dim oDataMedium As DataMedium
Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
Dim objFolder As Folder
Dim objFile 'As File
Set objFolder = objFS.GetFolder(strSourceFolder)
Debug.Print "Convert Content of Folder: " & strSourceFolder
For Each objFile In objFolder.Files
Dim strFullFilePath As String
strFullFilePath = objFile
If Right(objFile, Len(strSourceFileType)) = strSourceFileType Then
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Open(strFullFilePath)
If JTAddIn.HasSaveCopyAsOptions(oPartDoc, oContext, oOptions) = True Then
oOptions.Value("ConfigFilePath") = strConverterConfigFilePath
oOptions.Value("ConfigFileEnabled") = True
oContext.Type = kFileBrowseIOMechanism
strFullFilePath = Replace(strFullFilePath, strSourceFolder, strDestinationFolder)
End If
oDataMedium.FileName = strFullFilePath & strDestinationFileType
JTAddIn.SaveCopyAs oPartDoc, oContext, oOptions, oDataMedium
oPartDoc.Close True
Else
End If
oPartDoc.SaveAs strFullFilePath & strDestinationFileType, True
oPartDoc.Close True
End If
End If
Next objFile
End Function
