- Mute
- Permalink
- Report
Marshal.GetActiveObject fails with InventorServer Object. Help!
I'am trying to write some code on VS .NET Framework 4.6.1 and to generate a .dll file for my Inventor model that works on C360. So I can not use 'Inventor.Application' object. That's OK.
When I use 'Inventor.InventorServer' object, I can't set that object reference to the intance of my object. I think 'Marshal.GetActiveObject' does not work in this case. So what is the solution?
This is the error message: Object reference not set to an instance of an object.
This is related part of my code:
Dim oThisServer As Inventor.InventorServer = Nothing
Try
oThisServer = Marshal.GetActiveObject("Inventor.InventorServer")
Catch ex As Exception
Exit Sub
End Try
Thanks!
- Mute
- Permalink
- Report
Otherwise use createobject.....
Arthur Knoors
Autodesk Affiliations:
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
I think that Inventor Server can only be used in the context of a job.
GetActiveObject() can not get an instance, it will always returns null.
Inventor Server is started from C:\Program Files\Autodesk\Vault Client 20xx\Explorer\Inventor Server\Bin\VaultInventorServer.exe and then there is a specific process to connect to the running instance which can not be used by an external developer (only Autodesk can use this).
Manager
Add-ins development for Autodesk software products
http://wiip.fr
- Mute
- Permalink
- Report
That is correct.
You can only use it with a Vault JobProcessor Job!
Arthur Knoors
