chandra.shekar.g
in reply to: kwalker1
@kwalker1,
Try below iLogic code to get custom iProperty of ShriknWrap assembly without opening it. Unfortunately, suppressed shrikwrap assembly is unable to get custom iProperty.
Note: iLogic code should be run in PartDocument which contains ShrinkWrapComponent.
Sub Main()
	Dim oShrinkwrap As PartDocument
	oShrinkwrap = ThisApplication.ActiveDocument
	Dim oDef As PartComponentDefinition
	oDef = oShrinkwrap.ComponentDefinition
	Dim oShrinkComp As ShrinkwrapComponent
	For Each oShrinkComp In oDef.ReferenceComponents.ShrinkwrapComponents
		Dim oReferDoc As Document
        oReferDoc = oShrinkComp.ReferencedDocumentDescriptor.ReferencedDocument
		Dim oPropValue As String
		oPropValue = oReferDoc.PropertySets.Item(4).Item("STRUCTURE SAVE DATE & TIME STAMP").Value
		 MessageBox.Show(oPropValue, "Title")
	Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
