chandra.shekar.g
in reply to: kwalker1
@kwalker1,
Try below iLogic rule to update custom iProperty from ShrinkWrap component to part document.
Sub Main()
	Dim oShrinkwrap As PartDocument
	oShrinkwrap = ThisApplication.ActiveDocument
	Dim oDef As PartComponentDefinition
	oDef = oShrinkwrap.ComponentDefinition
	Dim oShrinkComp As ShrinkwrapComponent
	For Each oShrinkComp In oDef.ReferenceComponents.ShrinkwrapComponents
		oShrinkComp.SuppressLinkToFile = False
		iLogicVb.UpdateWhenDone = True
	Next
		Dim oReferDoc As Document
        oReferDoc = oShrinkComp.ReferencedDocumentDescriptor.ReferencedDocument
		Dim oPropValue As String
		oPropValue = oReferDoc.PropertySets.Item(4).Item("STRUCTURE SAVE DATE & TIME STAMP").Value
		oShrinkComp.SuppressLinkToFile = True
		iProperties.Value("Custom", "SHRINKWRAP SAVE DATE & TIME STAMP") = oPropValue
	Next
	'UPDATE SHRINKWRAP SAVE Date & TIME STAMP (CODE TEST 1)
	'UPDATE SHRINKWRAP SAVE DATE & TIME STAMP (CODE TEST 2)
	'Dim baseComponentFilePath As String
	'baseComponentFilePath = ThisDoc.Path + "\STRUCTURE ASSEMBLY.iam"
	'iProperties.Value("Custom", "SHRINKWRAP SAVE DATE & TIME STAMP") = iProperties.Value(baseComponentFilePath, "Custom", "STRUCTURE SAVE DATE & TIME STAMP")
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
