- Mute
- Permalink
- Report
Thanks very much Chandra for the information and adjusted code.
I have now installed Inventor 2019 and it works great.
But I'm encountering one other problem.
I'm trying to trigger the code to only run when the shrinkwrap file's Date & Time Stamp iproperty does not match the base component's Date & Time Stamp iproperty.
If triggered, the code will:
1. Unsuppress link with base component
2. Update the shrinkwrap
3. Re-suppresses link with base component
4. Then updates the shrinkwrap's Date & Time Stamp iproperty to match the base component's Date & Time Stamp iproperty.
The problem I'm having is that I can't seem to read the base component's iproperty because it is suppressed.
I have tried the following 2 pieces of code but both won't work for me.
Is there a way to call up an iproperty value of another file which has not be placed / derived / made active within the file that contains the code?
'UPDATE SHRINKWRAP SAVE Date & TIME STAMP
iProperties.Value("Custom", "SHRINKWRAP SAVE DATE & TIME STAMP") = iProperties.Value("STRUCTURE ASSEMBLY.iam", "Custom", "STRUCTURE SAVE DATE & TIME STAMP")
'UPDATE SHRINKWRAP SAVE DATE & TIME STAMP (CODE TEST 2)
Dim baseComponentFilePath As String
baseComponentFilePath = ThisDoc.Path + "\STRUCTURE ASSEMBLY.iam"
iProperties.Value("Custom", "SHRINKWRAP SAVE DATE & TIME STAMP") = iProperties.Value(baseComponentFilePath, "Custom", "STRUCTURE SAVE DATE & TIME STAMP")
I have attached an updated model with the code I'm using.
Many thanks for the help.
