- Mute
- Permalink
- Report
Dim oApp As Application
Dim oCurrentDoc As Document
Dim oNewDoc As Document
Dim UseDefaultTemplate As Boolean
Dim sCurrentFileName As String
Dim sTemplatePart As String
Set oApp = ThisApplication
Set oCurrentDoc = oApp.ActiveDocument
Select Case oApp.ActiveDocumentType
Case kAssemblyDocumentObject, kPartDocumentObject
sCurrentFileName = ThisApplication.ActiveDocument.FullFileName
If sCurrentFileName = "" Then
MsgBox "The active file must first be saved"
Exit Sub
End If
'if you want to use the default template then set UseDefaultTemaplte = True
'if you want to use a custom template set the path and filename of sTemplatePart and UseDefaultTemaplte = False
UseDefaultTemplate = False
sTemplatePart = "Q:\Inventor\Templates_v2017\part.ipt"
Select Case UseDefaultTemplate
Case True
Set oNewDoc = oApp.Documents.Add(kPartDocumentObject)
Case False
Set oNewDoc = oApp.Documents.Add(kPartDocumentObject, sTemplatePart, True)
End Select
'******START UPDATED CODE **************
'If your template has an active sketch you need to close it.
Dim oSketch As Sketch
On Error Resume Next
Set oSketch = oNewDoc.ComponentDefinition.Sketches.Item(1)
oSketch.ExitEdit
On Error GoTo 0
'******END UPDATED CODE **************
'Get the control definition that represents the derived part command.
Dim oDerivedCommandDef As ControlDefinition
Set oDerivedCommandDef = ThisApplication.CommandManager.ControlDefinitions.Item("PartDerivedComponentCmd")
'Post the filename to the private event queue.
Call ThisApplication.CommandManager.PostPrivateEvent(kFileNameEvent, sCurrentFileName)
'Start the derived part command.
oDerivedCommandDef.Execute
Case Else
MsgBox "You must first have a Part or Assembly document open"
End Select
