chandra.shekar.g
@Anonymous,
Try below iLogic code to color parts in assembly. In this example, there are 3 parts in assembly. So, code works for 3 colors only. It extended for different colors based on situations.
Sub Main()
    Dim oDoc As DrawingDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    oSheet = oDoc.ActiveSheet
    Dim layers As LayersEnumerator
    layers = oDoc.StylesManager.Layers
    On Error Resume Next
    Dim oRed As Layer
    oRed = layers.Item("Red")
    If Err.Number <> 0 Then
        On Error GoTo 0
        Dim redColor As Color
        redColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
        ' Copy an arbitrary layer giving it the name
        ' of the render style.
        oRed = layers.Item(1).Copy("Red")
        ' the attributes of the layer to use the color,
        ' have a solid line type, and a specific width.
        oRed.Color = redColor
        oRed.LineType = kContinuousLineType
        oRed.LineWeight = 0.02
     End If
    Dim oGreen As Layer
    oGreen = layers.Item("Green")
        On Error GoTo 0
        Dim greenColor As Color
        greenColor = ThisApplication.TransientObjects.CreateColor(0, 255, 0)
        oGreen = layers.Item(1).Copy("Green")
        oGreen.Color = greenColor
        oGreen.LineType = kContinuousLineType
        oGreen.LineWeight = 0.02
     End If
    Dim oBlue As Layer
    oBlue = layers.Item("Blue")
        On Error GoTo 0
        Dim blueColor As Color
        blueColor = ThisApplication.TransientObjects.CreateColor(0, 0, 255)
        oBlue = layers.Item(1).Copy("Blue")
        oBlue.Color = blueColor
        oBlue.LineType = kContinuousLineType
        oBlue.LineWeight = 0.02
     End If
     Dim colorColl As ObjectCollection
     colorColl = ThisApplication.TransientObjects.CreateObjectCollection
     Call colorColl.Add(oRed)
     Call colorColl.Add(oBlue)
     Call colorColl.Add(oGreen)
    Dim oView As DrawingView
    For Each oView In oSheet.DrawingViews
        Dim oReferDoc As AssemblyDocument
        oReferDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
        Dim oAssyDef As AssemblyComponentDefinition
        oAssyDef = oReferDoc.ComponentDefinition
        Dim occDoc As Document
        Dim cnt As Integer
        cnt = 1
        For Each occDoc In oReferDoc.AllReferencedDocuments
            Dim occ As ComponentOccurrence
            For Each occ In oAssyDef.Occurrences
                If occ.ReferencedDocumentDescriptor.ReferencedDocument Is occDoc Then
                    Dim oCurves As DrawingCurvesEnumerator
                    oCurves = oView.DrawingCurves(occ)
                    Dim oCurve As DrawingCurve
                    For Each oCurve In oCurves
                        Dim oColl As ObjectCollection
                        oColl = ThisApplication.TransientObjects.CreateObjectCollection
                        Dim oSegment As DrawingCurveSegment
                        For Each oSegment In oCurve.Segments
                            Call oColl.Add(oSegment)
                        Next
                        Call oSheet.ChangeLayer(oColl, colorColl.Item(cnt))
                        Call oDoc.Update
                    Next
                End If
            Next
            cnt = cnt + 1
        Next
    Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
