DRoam
in reply to: DRoam
I'm not sure what version of Inventor you have, but if you have 2017 or newer, you can take a look at the attached example part that demonstrates how to use iLogic to control the number/suppression of holes.
When you open the part, it should open a control form. Drag the slider back and forth to see it adjust the number of holes and their spacing. Below 1000 mm, it suppresses them altogether.
Hope this helps.
