- Mute
- Permalink
- Report
Ilogic check if layer is empty
Well my question is quite simple. Is there a way with iLogic to see if a layer is empty?
I could check all the curves in all views in an .IDW and see if any curve is on the pointed layer...But just checking if its empty would be better and faster.
Sorry if it's been asked before... I made a quick search and couldn't find it.
Thks in advance
- Mute
- Permalink
- Report
What do you mean with empty?
Do you actually not used in the drawing?
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Autodesk Affiliations:
