atomic.lex
931 Views, 8 Replies
Inventor: Setting parameter tolerance with iLogic has wrong results
I have a error by setting parameter tolerance
Set d3_Tol As String = "d13"
Parameter.Param("d3").Tolerance.SetToFits(31244,(""),(d3_Tol))
The code should bring parameter  tolerance d13 (-0.065 / -0,395 ), but i get 10x values:
Why is it so?
Many thanks for advice.
Good luck, Alex
@atomic.lex,
marius.gildehaus has edited your subject line for clarity
Original: Setting parameter tolerance error
