chandra.shekar.g
in reply to: clutsa
@ACEDeSmedt,
Engineering team knows about Launch_Viewer option which is not working for PDF translator. A change request is already created with engineering team and details are given below.
INVGEN - 2958 - API: The Launch_Viewer option for PDF translator does not work (Display Published File in Viewer)
As a workaround, you can try suggestion in below forum discussion link.
https://forums.autodesk.com/t5/inventor-customization/pdfaddin-option-quot-launch-viewer-quot-true-o...
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
