ACEDeSmedt
669 Views, 3 Replies
Export To PDF options
While exporting to PDF Through VBA (api), it is not possible to alter the option Print excluded sheets and Display Published File in Viewer. (see screenshot):Export -> PDF -> optionsExport -> PDF -> options
 What I tried so far without success:
  • Searching for the options here on the forum: only 6 options found.
  • Using the Translator.HasSaveCopyAsOptions to get the default options:
    I've found 43 options, including the previous 6 and an options Launch_Viewer
  • Launch_Viewer = False didn't work
  • I've tried ViewPDFWhenFinished = False (option found for 3D PDF)
Any help or suggestion in the right direction would be welcome.
If this is the solution, push the solution button :winking_face: (and maybe some kudos)
Autodesk Product Design Suit - Ultimate edition (Subscription)
