11-05-2018
11:43 AM
- Mute
- Permalink
- Report
11-05-2018
11:43 AM
Attached are the models. The code runs on a button click and I did notice a couple lines I forgot to change back. The line thirdnode.Expanded = True should be oView.SetIncludeStatus(thirdnode.NativeObject, True) and the other thirdnode.Expanded = True should be replaced with oView.SetIncludeStatus(fourthnode.NativeObject, True). See corrected code below. I noticed I have this issue with parts created within a weldment and not as a new part. Because I am referencing other parts to create the new part, it appears to throw off the 3D sketch when including it because of its orientation relative to the UCS. Not sure how to include it with respect to the weldment UCS.
Public Sub CMandCL(ThisApplication As Inventor.Application)
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
If oDrawDoc.SelectSet.Count = 0 Then
MsgBox("Please select at least one view.")
Else
Dim obj As Object
For Each obj In oDrawDoc.SelectSet
If TypeOf obj Is DrawingView Then
Dim oView As DrawingView = obj
oView.SetAutomatedCenterlineSettings()
Dim modelpane As BrowserPane = oDrawDoc.BrowserPanes.Item("Model")
For Each node As BrowserNode In modelpane.TopNode.BrowserNodes
Dim nodedef As BrowserNodeDefinition = node.BrowserNodeDefinition
If nodedef.Label = oSheet.Name Then
For Each viewnode As BrowserNode In node.BrowserNodes
Dim viewnodedef As BrowserNodeDefinition = viewnode.BrowserNodeDefinition
If viewnodedef.Label.StartsWith(oView.Name) Then
Dim firstnode As BrowserNode = viewnode.BrowserNodes.Item(1)
For Each secondnode As BrowserNode In firstnode.BrowserNodes
For Each thirdnode As BrowserNode In secondnode.BrowserNodes
Dim thirdnodedef As BrowserNodeDefinition = thirdnode.BrowserNodeDefinition
If thirdnodedef.Label.StartsWith("3D") Then
Dim sketch As Object = thirdnode.NativeObject
If oView.GetVisibility(sketch) = False Then
'oView.SetIncludeStatus(thirdnode.NativeObject, True)
End If
Else
For Each fourthnode As BrowserNode In thirdnode.BrowserNodes
Dim fourthnodedef As BrowserNodeDefinition = fourthnode.BrowserNodeDefinition
If fourthnodedef.Label.StartsWith("3D") Then
Dim sketch As Object = fourthnode.NativeObject
fourthnode.Expanded = True
'oView.SetIncludeStatus(fourthnode.NativeObject, True)
End If
End If
Next
End If
Next
Next
End If
Next
End If
Next
'Dim model As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
'For Each doc As _Document In model.AllReferencedDocuments
' If TypeOf doc Is PartDocument Then
' Dim pdoc As PartDocument = doc
' Dim pdef As PartComponentDefinition = pdoc.ComponentDefinition
' Dim threedsketch As Sketch3D
' For Each threedsketch In pdef.Sketches3D
' oView.SetIncludeStatus(threedsketch, True)
' Next
' threedsketch = Nothing
' pdoc = Nothing
' End If
' doc = Nothing
'Next
'model = Nothing
oView = Nothing
End If
Next
obj = Nothing
End If
End Sub
