11-05-2018
07:48 AM
- Mute
- Permalink
- Report
11-05-2018
07:48 AM
Thanks, that was the hint I needed. I have written two examples in VBA how to get the names of all surfaces and how to get the names of selected surfaces. I need this in order to name a sketch according to the area from which it is originated.
Sub Get_AllNames_from_Faces()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oCompDef As ComponentDefinition
Set oCompDef = oDoc.ComponentDefinition
Dim oFaces As Faces
Set oFaces = oCompDef.SurfaceBodies(1).Faces
Dim AttSets As AttributeSets
Dim AttSet As AttributeSet
For Each oface In oFaces
Set AttSets = oface.AttributeSets
If AttSets.NameIsUsed("iLogicEntityNameSet") Then
Set AttSet = AttSets.item("iLogicEntityNameSet")
For Each Att In AttSet
Debug.Print ("Face Value: " & Att.Value)
Next
End If
Next
End Sub
Sub Get_SelectedNames_from_Faces()
Dim CompDef As ComponentDefinition
Set CompDef = oDoc.ComponentDefinition
Dim oSelect As SelectSet
Set oSelect = oDoc.SelectSet
Dim oFaces As Faces
Set oFaces = CompDef.SurfaceBodies(1).Faces
For Each item In oSelect
Set AttSets = item.AttributeSets
If Att.Name = "iLogicEntityName" Then
'Get only the displayed Name of the Face
End If
Next
End If
Next
End Sub
Best Regards Martin
